메인 콘텐츠로 스킵하기
도움말
Dell Inspiron 9100 Memory Replacement
단계 다듬기
단계 다듬기
해당 안내서에는 불필요한 단계들이 있습니다. 단계들을 다듬어 더욱 간결하게 만들어 주십시오!
Removal of Memory Modules
This guide will help you replace the RAM (memory module) on your Dell Inspiron 9100. It is useful to replace the RAM if your computer runs slower than normal or if your programs constantly freeze.
This guide requires a Phillips #00 screwdriver.
섹션
도구
단계 1 Memory  ¶
Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M." This screw will remain in the panel.
단계 1 Memory  ¶
  • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
  • This screw will remain in the panel.
  • Pull the cover away from the laptop using your finger.
단계 2  ¶
Use your fingertips to carefully spread apart the plastic white tabs. Flip the RAM up at a 45 degree angle and remove it. Hold the RAM by the edges only.
단계 2  ¶
  • Use your fingertips to carefully spread apart the plastic white tabs.
  • Flip the RAM up at a 45 degree angle and remove it.
  • Hold the RAM by the edges only.
  • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
단계 3  ¶
Repeat step four with the second RAM.
단계 3  ¶
  • Repeat step four with the second RAM.
