메인 콘텐츠로 스킵하기
도움말
Palm m500 Vibration Motor Replacement
This guide will detail how to disassemble the device and replace the vibration motor.
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will be removing the stylus, the back panel, the battery, and the motherboard in order to replace the vibration motor.
섹션
단계 1 Vibration Motor  ¶
Use tweezers to gently pull the vibration motor away from the front panel. The vibration motor is unsecured and should be easy to remove from the front panel. The vibration motor is unsecured and should be easy to remove from the front panel.
  • Use tweezers to gently pull the vibration motor away from the front panel.
  • The vibration motor is unsecured and should be easy to remove from the front panel.
