도움말
MacBook Core Duo Upper Case Clips Replacement
MacBook Core Duo upper case clip replacement.
Use this guide to replace the gray plastic upper case clips that secure the upper case above the optical drive opening.
섹션
도구
단계 1 Upper Case Clips  ¶
The clips are captive to the lower case on Santa Rosa MacBooks and later and are thus not replaceable on these models. The four plastic upper case clips are installed in the aluminum framework above the optical drive opening. To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
  • The clips are captive to the lower case on Santa Rosa MacBooks and later and are thus not replaceable on these models.
  • The four plastic upper case clips are installed in the aluminum framework above the optical drive opening.
  • To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
