메인 콘텐츠로 스킵하기
도움말
Nintendo DS Lite Upper Case Replacement
Replacement of Nintendo DS Lite Upper Case
  • 작성자: Matthew Newsom
  • 예상 시간 30 - 50 분
  • 난이도: 보통
Replace your scratched and scuffed upper case to make your DS Lite look like new.
섹션
단계 1 Upper Case  ¶
Remove the two 8.3 mm Phillips screws securing the upper case to the display assembly.
단계 1 Upper Case  ¶
  • Remove the two 8.3 mm Phillips screws securing the upper case to the display assembly.
단계 2  ¶
Pull the upper LCD ribbon cable to the right, through the slit in the case. Push the ribbon cable down through the slit.
단계 2  ¶
  • Pull the upper LCD ribbon cable to the right, through the slit in the case.
  • Push the ribbon cable down through the slit.
단계 3  ¶
Slowly lift the upper case away from the display, making sure the ribbon cable does not get caught. Slowly lift the upper case away from the display, making sure the ribbon cable does not get caught.
단계 3  ¶
  • Slowly lift the upper case away from the display, making sure the ribbon cable does not get caught.
단계 4  ¶
Once the ribbon cable is free from the upper case, pull the antenna and Wi-Fi cables through the hole in the upper case. Remove the upper case from the DS Lite.
단계 4  ¶
  • Once the ribbon cable is free from the upper case, pull the antenna and Wi-Fi cables through the hole in the upper case.
  • Remove the upper case from the DS Lite.
