메인 콘텐츠로 스킵하기
도움말
MacBook Pro 15" Core Duo Model A1150 Memory Door Replacement
  • 작성자: iRobot
  • 난이도: 쉬움
Removing a few screws will remove this part and allow access to your RAM.
단계 1 Memory Door  ¶
Remove the three identical Phillips screws from the memory door.
단계 1 Memory Door  ¶
  • Remove the three identical Phillips screws from the memory door.
  • Make sure to record which sets of screws came from where. This will help when re-assembling.
단계 2  ¶
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
단계 2  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
