메인 콘텐츠로 스킵하기
도움말
Disassembling Samsung DVD-P230 Outer Cover & Faceplate
This guide will show the process for removing the outer cover and front faceplate of the Samsung DVD-P230.
This is the first few steps for disassembling the DVD player.
단계 1 Outer Cover & Faceplate  ¶
Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  • Open the tray by pressing the eject button
  • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
단계 2  ¶
Press the eject button to insert the tray
단계 2  ¶
  • Press the eject button to insert the tray
  • After the tray is closed unplug DVD player
단계 3  ¶
Unscrew the 3 screws in the back.
단계 3  ¶
  • Unscrew the 3 screws in the back.
단계 4  ¶
Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
단계 4  ¶
  • Pull the outer case upward and then towards you.
단계 5  ¶
There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
단계 5  ¶
  • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
단계 6  ¶
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
단계 6  ¶
  • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
