메인 콘텐츠로 스킵하기
도움말
MacBook Pro 15" Core Duo Model A1150 Right Fan Replacement
  • 작성자: iRobot
  • 예상 시간 30 분 - 2 시간
  • 난이도: 보통
Replacing a defective fan is pretty easy and will keep your laptop running cool.
섹션
도구
단계 1 Right Fan  ¶
Disconnect the right fan cable from the logic board.
단계 1 Right Fan  ¶
  • Disconnect the right fan cable from the logic board.
단계 2  ¶
Peel up the orange Kapton tape securing the right speaker cables above the right fan.
단계 2  ¶
  • Peel up the orange Kapton tape securing the right speaker cables above the right fan.
단계 3  ¶
Remove the three silver T6 Torx screws securing the right fan to the logic board and lower case.
단계 3  ¶
  • Remove the three silver T6 Torx screws securing the right fan to the logic board and lower case.
단계 4  ¶
Hold up the gray and black speaker cable with one hand. Use your other hand to lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
단계 4  ¶
  • Hold up the gray and black speaker cable with one hand. Use your other hand to lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
