메인 콘텐츠로 스킵하기
도움말
MacBook Pro 15" Core Duo Model A1150 ExpressCard Cage Replacement
  • 작성자: iRobot
  • 난이도: 어려움
You can again use ExpressCard accessories by replacing a faulty ExpressCard cage.
섹션
도구
단계 1 ExpressCard Cage  ¶
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
단계 2  ¶
Disconnect the two antenna cables attached to the Airport Extreme card.
단계 2  ¶
  • Disconnect the two antenna cables attached to the Airport Extreme card.
  • The white antenna cable connects to the left side of the Airport Extreme card.
단계 3  ¶
Remove the single silver Phillips screw located just above the Airport Extreme card.
단계 3  ¶
  • Remove the single silver Phillips screw located just above the Airport Extreme card.
  • Lift the small silver metal retaining bracket up and out of the computer.
단계 4  ¶
Peel back the orange tape on the right side of the Airport Extreme card.
단계 4  ¶
  • Peel back the orange tape on the right side of the Airport Extreme card.
  • Lift the Airport Extreme card up and slide it out of its connector.
단계 5  ¶
Peel up the orange hard drive cable from above the ExpressCard cage.
단계 5  ¶
  • Peel up the orange hard drive cable from above the ExpressCard cage.
단계 6  ¶
Disconnect the speaker cable from the corner of the left I/O board.
단계 6  ¶
  • Disconnect the speaker cable from the corner of the left I/O board.
단계 7  ¶
Remove the single black T6 Torx screw securing the left speaker.
단계 7  ¶
  • Remove the single black T6 Torx screw securing the left speaker.
단계 8  ¶
Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
단계 8  ¶
  • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
단계 9  ¶
Disconnect the large multi-colored power cable from the left I/O board.
단계 9  ¶
  • Disconnect the large multi-colored power cable from the left I/O board.
단계 10  ¶
Remove the following 5 screws/standoffs:
단계 10  ¶
  • Remove the following 5 screws/standoffs:
  • Four black T6 Torx screws securing the left I/O board to the lower case.
  • One 4 mm standoff located between the audio jacks.
단계 11  ¶
Lift up the right side of the left I/O board and slide it out of the computer.
단계 11  ¶
  • Lift up the right side of the left I/O board and slide it out of the computer.
단계 12  ¶
Remove the following 4 screws:
단계 12  ¶
  • Remove the following 4 screws:
  • Three 1.2 mm silver Phillips with large heads.
  • One 3.2 mm black Phillips on the left side.
단계 13  ¶
Lift the left I/O board off the ExpressCard cage.
단계 13  ¶
  • Lift the left I/O board off the ExpressCard cage.
