도움말
LG G Pad 10.1 Motherboard Replacement
This guide will give step-by-step instructions on how to remove the motherboard from your LG G Pad 10.1 tablet.
This guide will show you how to access the motherboard, which screws and cables to remove and disconnect, and where the plastic clips are to separate the board from the device.
단계 1 Motherboard  ¶
Remove the five 2 mm Phillips #000 screws securing the motherboard.
단계 1 Motherboard  ¶
  • Remove the five 2 mm Phillips #000 screws securing the motherboard.
  • The silver EMI shield may come off during this step. Just set it aside until reassembly.
단계 2  ¶
Remove the two 5 mm Phillips #000 securing the motherboard,
단계 2  ¶
  • Remove the two 5 mm Phillips #000 securing the motherboard,
단계 3  ¶
Disconnect the cable from the battery to the motherboard by grabbing the cable and pulling upwards.
단계 3  ¶
  • Disconnect the cable from the battery to the motherboard by grabbing the cable and pulling upwards.
단계 4  ¶
Using the spudger, pry up the connector on the motherboard from the back camera to disconnect it. Using the spudger, pry up the connector on the motherboard from the back camera to disconnect it.
단계 4  ¶
  • Using the spudger, pry up the connector on the motherboard from the back camera to disconnect it.
단계 5  ¶
Then move to the front camera towards the end of the motherboard and disconnect that by using the spudger to pull up on the clip.
단계 5  ¶
  • Then move to the front camera towards the end of the motherboard and disconnect that by using the spudger to pull up on the clip.
단계 6  ¶
Now that all of the wires and screws are disconnected, use the spudger or a prying tool on the bottom corner of the motherboard to release it from one of the clips holding it in place.
단계 6  ¶
  • Now that all of the wires and screws are disconnected, use the spudger or a prying tool on the bottom corner of the motherboard to release it from one of the clips holding it in place.
단계 7  ¶
Once the corner is removed, repeat the same action at the far end of the motherboard to release the second clip.
단계 7  ¶
  • Once the corner is removed, repeat the same action at the far end of the motherboard to release the second clip.
