메인 콘텐츠로 스킵하기
도움말
iPhone 6s Plus Opening Procedure
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
Open an iPhone 6s Plus.
Prerequisite only: Follow this guide to open your iPhone 6s Plus.
단계 1 Opening Procedure  ¶
Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
  • Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
  • Heat softens the adhesive securing the display, making it easier to open.
단계 2  ¶
Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
단계 2  ¶
  • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
  • Apply a suction cup to the lower left corner of the display assembly.
단계 3  ¶
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
단계 3  ¶
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
단계 4  ¶
The safest place to pry from is the notch in the front panel above the headphone jack. While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack. While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
단계 4  ¶
  • The safest place to pry from is the notch in the front panel above the headphone jack.
  • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
단계 5  ¶
Twist the spudger to widen the gap between the front panel and the rear case. Twist the spudger to widen the gap between the front panel and the rear case.
단계 5  ¶
  • Twist the spudger to widen the gap between the front panel and the rear case.
단계 6  ¶
While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
단계 6  ¶
  • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
단계 7  ¶
Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case. Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
단계 7  ¶
  • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
단계 8  ¶
Insert the flat tip of the spudger under the right edge of the display. Slide the spudger up the right side.
단계 8  ¶
  • Insert the flat tip of the spudger under the right edge of the display.
  • Slide the spudger up the right side.
단계 9  ¶
Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone. Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
단계 9  ¶
  • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
  • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
단계 10  ¶
Pull up on the small nub on the suction cup to remove it from the display. Pull up on the small nub on the suction cup to remove it from the display.
단계 10  ¶
  • Pull up on the small nub on the suction cup to remove it from the display.
단계 11  ¶
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
단계 11  ¶
  • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
  • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
  • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
  • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  • In a pinch, you can use an unopened canned beverage to support the display.
