메인 콘텐츠로 스킵하기
도움말
Battery Connector
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
Prerequisite Only: Disconnect the battery connector in an iPhone 6s Plus.
Follow this guide to disconnect the battery connector in an iPhone 6s Plus. You should disconnect the battery before performing any other internal repairs to prevent shorting any sensitive components in the phone.
단계 1 Battery Connector  ¶
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
  • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
  • One 2.9 mm screw
  • One 2.3 mm screw
  • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
단계 2  ¶
Remove the battery connector bracket. Remove the battery connector bracket.
단계 2  ¶
  • Remove the battery connector bracket.
단계 3  ¶
Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
단계 3  ¶
  • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
단계 4  ¶
Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
단계 4  ¶
  • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
