메인 콘텐츠로 스킵하기
도움말
MacBook Core 2 Duo Optical Drive Replacement
  • 작성자: iRobot
  • 난이도: 보통
Upgrade or replace the combo or SuperDrive (requires a slim drive). Be sure to determine which model Macbook you have when installing new parts because earlier models have a PATA/IDE connection to the motherboard rather than SATA.
단계 1 Optical Drive  ¶
Use a spudger to carefully pry the silver metal bracket off the left side of the optical drive. Be careful not to bend the bracket, as it is very thin and bends easily. If the bracket doesn't come free easily, heating the adhesive may make prying the bracket off easier.
  • Use a spudger to carefully pry the silver metal bracket off the left side of the optical drive. Be careful not to bend the bracket, as it is very thin and bends easily. If the bracket doesn't come free easily, heating the adhesive may make prying the bracket off easier.
단계 2  ¶
Peel up the L-shaped piece of black tape from the top of the drive.
단계 2  ¶
  • Peel up the L-shaped piece of black tape from the top of the drive.
  • You'll want to reapply this tape in the same position on your replacement drive.
단계 3  ¶
Peel up the silver foil tape from the optical drive.
단계 3  ¶
  • Peel up the silver foil tape from the optical drive.
단계 4  ¶
Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
단계 4  ¶
  • Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
  • This bracket is designed to slide back and forth slightly, so don't tighten the screws so much that the bracket is unable to slide.
단계 5  ¶
Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
단계 5  ¶
  • Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
  • You'll want to reapply this piece in the same position on your replacement drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
