메인 콘텐츠로 스킵하기
도움말
HP Pavilion dv1000 Hard Drive Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
This guide gives step-by-step instructions on how to install or replace a hard drive in the HP Pavilion dv1000 laptop.
  • 작성자: John Park
  • 예상 시간 10 분
  • 난이도: 아주 쉬움
Replacing the hard drive in HP's dv1000 is not complicated and requires no prior experience with electronics to complete successfully.
섹션
도구
단계 1 Hard Drive  ¶
With the battery removed, locate the hard drive access panel.
단계 1 Hard Drive  ¶
  • With the battery removed, locate the hard drive access panel.
단계 2  ¶
Identify the two screws that attach the hard drive access panel. Remove the identified screws with your #00 Philips screwdriver. Lift the left edge of the access panel up and to the right to detach the hard drive access panel from the laptop.
단계 2  ¶
  • Identify the two screws that attach the hard drive access panel.
  • Remove the identified screws with your #00 Philips screwdriver.
  • Lift the left edge of the access panel up and to the right to detach the hard drive access panel from the laptop.
단계 3  ¶
This particular laptop does not contain a hard drive-- yours will.
단계 3  ¶
  • This particular laptop does not contain a hard drive-- yours will.
  • Identify the plastic tab located on the left side of the hard drive.
  • Grasp the tab, gently lift up, and slide the tab to the left to remove the hard drive from the laptop.
  • If you wish to replace your hard drive with another, the hard drive has a metal bracket screwed onto the sides of the casing. Unscrew the bracket from the old hard drive and screw it onto the new hard drive before inserting into the laptop.
