메인 콘텐츠로 스킵하기
도움말
MacBook Core 2 Duo Display Replacement
  • 작성자: iRobot
  • 예상 시간 1 - 2 시간
  • 난이도: 어려움
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
단계 1 Display  ¶
Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
단계 1 Display  ¶
  • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
  • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
단계 2  ¶
Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
단계 2  ¶
  • Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
  • This metal clip may not be present in all models. Be sure that the cable is free from any hold downs around this area before proceeding.
단계 3  ¶
If you didn't remove the ground loop screw in step 20 above, remove it now.  It's a 7 mm (may be 4.2 mm in Santa Rosa/Penryn models) Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
단계 3  ¶
  • If you didn't remove the ground loop screw in step 20 above, remove it now. It's a 7 mm (may be 4.2 mm in Santa Rosa/Penryn models) Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
단계 4  ¶
Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
단계 4  ¶
  • Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
단계 5  ¶
Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
단계 5  ¶
  • Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
단계 6  ¶
Disconnect the three antenna cables from the Airport card.  There may be a square foam piece over the logic board connector. Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.)  The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
단계 6  ¶
  • Disconnect the three antenna cables from the Airport card. There may be a square foam piece over the logic board connector.
  • Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.) The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
  • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, there are only two antenna cables and the black inverter cable is in a different location.
단계 7  ¶
Remove the following 2 screws from the right hinge mount: One 6 mm Phillips on the left side of the hinge mount.
단계 7  ¶
  • Remove the following 2 screws from the right hinge mount:
  • One 6 mm Phillips on the left side of the hinge mount.
  • One 10 mm Phillips on the right side of the hinge mount.
  • For Santa Rosa/Penryn models, see second picture and remove:
  • One 3 mm smalller diameter Phillips on the far left.
  • One 5.2 mm larger diameter 4.2 mm head Phillips in the middle.
  • One 10 mm Phillips from the far right.
  • Lift the right hinge mount with the small plastic piece out of the computer.
단계 8  ¶
Hold the display with one hand while removing the screws from the left hinge mount.
단계 8  ¶
  • Hold the display with one hand while removing the screws from the left hinge mount.
  • Remove the following 3 screws from the left hinge mount:
  • One 7.2 mm smaller diameter Phillips from the right side.
  • One 5.2 mm larger diameter Phillips from the middle.
  • One 10 mm Phillips from the left side.
  • Lift the left hinge mount with plastic piece out of the computer.
  • Check that the cables on the right are not trapped under other cables.
  • Before completely disassembling, take care to see how the left hing mount fits together. When you remove the display in later steps, the hinge will pop both the left and right hinge mounts out, along with two small plastic pieces. Knowing how the mount fits together will help with reassembly.
단계 9  ¶
Grasp the display assembly on either side, and lift it up and out of the computer.
단계 9  ¶
  • Grasp the display assembly on either side, and lift it up and out of the computer.
