메인 콘텐츠로 스킵하기
도움말
iPad 2 Wi-Fi EMC 2415 Bluetooth/Wi-Fi Antenna Replacement
Replace a broken antenna in your iPad 2 Wi-Fi EMC 2415.
  • 작성자: Andrew Bookholt
  • 예상 시간 2 - 4 시간
  • 난이도: 매우 어려움
Use this guide to replace a broken antenna.
단계 1 Bluetooth/Wi-Fi Antenna  ¶
Move the dock connector/speaker cables out of the way and peel the Bluetooth/Wi-Fi antenna cable off the adhesive securing it to the rear case.
  • Move the dock connector/speaker cables out of the way and peel the Bluetooth/Wi-Fi antenna cable off the adhesive securing it to the rear case.
단계 2  ¶
Remove the following screws securing the Bluetooth/Wi-Fi antenna to the rear case:
단계 2  ¶
  • Remove the following screws securing the Bluetooth/Wi-Fi antenna to the rear case:
  • Two 1.7 mm Phillips screws
  • Two 2.0 mm Phillips screws
단계 3  ¶
Peel the Bluetooth/Wi-Fi antenna off the speaker enclosure and remove it from the iPad 2.
단계 3  ¶
  • Peel the Bluetooth/Wi-Fi antenna off the speaker enclosure and remove it from the iPad 2.
