메인 콘텐츠로 스킵하기
도움말
APS Tech 101629 External Casing Replacement
This guide will give instructions on removing the external case of the APS 101629 CD-Drive so that the internal components can be accessed.
  • 작성자: Patrick Meyer
  • 예상 시간 10 분
  • 난이도: 쉬움
This is one of the easier disassembly guides for this device. The case is easily removed, but will void any still existing warranty on the device. Removing the case is necessary to get at any internal component.
단계 1 External Casing  ¶
Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
  • Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
단계 2  ¶
Unscrew the four screws previously covered by the feet. Unscrew the four screws previously covered by the feet.
단계 2  ¶
  • Unscrew the four screws previously covered by the feet.
단계 3  ¶
Flip the device right side up, then gently slide the casing upwards and off the hard drive. Flip the device right side up, then gently slide the casing upwards and off the hard drive.
단계 3  ¶
  • Flip the device right side up, then gently slide the casing upwards and off the hard drive.
단계 4  ¶
Flip device upside down again.
단계 4  ¶
  • Flip device upside down again.
  • Gently pry the bottom gray casing away from the device.
단계 5  ¶
Rotate so back of device is facing you, then gently pry the back casing away. When back casing is removed, the fan will become loose.
단계 5  ¶
  • Rotate so back of device is facing you, then gently pry the back casing away.
  • When back casing is removed, the fan will become loose.
