도움말
PowerBook 3400 M3553 Hard Drive Replacement
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
How to remove the hard drive.
If your hard drive was damaged or you want to upgrade it you will need to remove the old hard drive first. However, the hard drive is one of the hardest components to reach. Make sure you are able to keep all removed parts organized to make your reassembly process easier.
섹션
단계 1 Hard Drive  ¶
Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive. Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
단계 1 Hard Drive  ¶
  • Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
단계 2  ¶
A ribbon cable is attached to the underside of the hard drive. Hasty removal of the hard drive can damage the ribbon cable.
단계 2  ¶
  • A ribbon cable is attached to the underside of the hard drive. Hasty removal of the hard drive can damage the ribbon cable.
  • Gently lift up on the hard drive.
단계 3  ¶
Rotate the hard drive towards yourself to access the ribbon cable and then gently pull up on the ribbon cable connector to remove the cable. You might find it easier to set the hard drive on its side while disconnect the ribbon cable.
단계 3  ¶
  • Rotate the hard drive towards yourself to access the ribbon cable and then gently pull up on the ribbon cable connector to remove the cable.
  • You might find it easier to set the hard drive on its side while disconnect the ribbon cable.
단계 4  ¶
Place the hard drive so that the casing is facing up.
단계 4  ¶
  • Place the hard drive so that the casing is facing up.
  • Remove the 4 T8 5mm long torx screws to remove the hard drive from the metal casing.
단계 5  ¶
Lift the metal casing off of the hard drive.
단계 5  ¶
  • Lift the metal casing off of the hard drive.
단계 6  ¶
Remove and set aside the black protector that was under the hard drive casing.
단계 6  ¶
  • Remove and set aside the black protector that was under the hard drive casing.
단계 7  ¶
If your replacement drive did not come with a ribbon cable, use a plastic opening tool to remove the ribbon cable from your old hard drive. Use a plastic opening tool to loosen the ribbon cable by running it along the connection and gently prying it free. When you have loosened the connection, pull the tab to remove the ribbon cable.
단계 7  ¶
  • If your replacement drive did not come with a ribbon cable, use a plastic opening tool to remove the ribbon cable from your old hard drive.
  • Use a plastic opening tool to loosen the ribbon cable by running it along the connection and gently prying it free.
  • When you have loosened the connection, pull the tab to remove the ribbon cable.
