메인 콘텐츠로 스킵하기
도움말
Canon EOS A2 Front Cover Replacement
Removing front cover to give access to lens housing.
  • 작성자: Mark
  • 예상 시간 10 - 15 분
  • 난이도: 쉬움
Removing the front cover gives access to lens housing, and allows removal of the top cover.
단계 1 Front Cover  ¶
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
단계 1 Front Cover  ¶
  • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
단계 2  ¶
Remove the 6.4mm screw from the inside of the flash bezel.
단계 2  ¶
  • Remove the 6.4mm screw from the inside of the flash bezel.
단계 3  ¶
Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
단계 3  ¶
  • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
단계 4  ¶
Remove the 5.6mm screws behind the battery cover.
단계 4  ¶
  • Remove the 5.6mm screws behind the battery cover.
단계 5  ¶
Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
단계 5  ¶
  • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
단계 6  ¶
Remove the 6.4mm screw on the top of the inside edge of the battery hole.
단계 6  ¶
  • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
단계 7  ¶
Starting at the flash, carefully pull the front cover away from the camera. Starting at the flash, carefully pull the front cover away from the camera.
단계 7  ¶
  • Starting at the flash, carefully pull the front cover away from the camera.
