메인 콘텐츠로 스킵하기
도움말
MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement
Replace the left fan in the MacBook Pro 15" Retina Display Mid 2015.
Use this guide to replace a broken or noisy left fan in your MacBook Pro 15" Retina Display Mid 2015.
Note that the left fan is on the left of the machine while you're using it, and on the right while you're working on it.
단계 1 Left Fan  ¶
Peel the left rubber cover up off the fan and fold it out of the way. Peel the left rubber cover up off the fan and fold it out of the way.
단계 1 Left Fan  ¶
  • Peel the left rubber cover up off the fan and fold it out of the way.
단계 2  ¶
Remove the following three screws securing the left fan to the logic board:
단계 2  ¶
  • Remove the following three screws securing the left fan to the logic board:
  • One 3.6 mm T5 Torx screw with a wide head
  • One 5.0 mm T5 Torx screw with a 2.0 mm long shoulder
  • One 4.4 mm T5 Torx screw
단계 3  ¶
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
단계 3  ¶
  • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
단계 4  ¶
Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket. The fan cable may be adhered to the logic board—to avoid tearing the cable, gently peel it up while lifting the fan.
단계 4  ¶
  • Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
  • The fan cable may be adhered to the logic board—to avoid tearing the cable, gently peel it up while lifting the fan.
  • Remove the fan.
