메인 콘텐츠로 스킵하기
도움말
HP PSC 2410 Photosmart All In One Printer Printer Carriage Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
단계 다듬기
단계 다듬기
해당 안내서에는 불필요한 단계들이 있습니다. 단계들을 다듬어 더욱 간결하게 만들어 주십시오!
With this guide you will remove the old printer carriage and replace it with a new one.
  • 작성자: Cody Long
  • 예상 시간 10 - 20 분
  • 난이도: 보통
In order to perform this installation see the guide for Removing Scanner Tray. After the scanner tray is removed the steps to replace the printer carriage are simple.
섹션
도구
관련 부품
단계 1 Printer Carriage  ¶
Remove printer carriage cover by unscrewing 4 black coarse thread T-10 torx screws marked with red circles.
  • Remove printer carriage cover by unscrewing 4 black coarse thread T-10 torx screws marked with red circles.
단계 2  ¶
Depress the plastic tabs marked in yellow to release the cover from the sides.
단계 2  ¶
  • Depress the plastic tabs marked in yellow to release the cover from the sides.
단계 3  ¶
Slide the printer carriage to the center of the printer. Disconnect the printer carriage from the rod one side at a a time by pulling upward. Unhooking the printer carriage is difficult and will require a fair amount of force. The plastic strip that guides the carriage is fragile and can be broken easily.
단계 3  ¶
  • Slide the printer carriage to the center of the printer. Disconnect the printer carriage from the rod one side at a a time by pulling upward.
  • Unhooking the printer carriage is difficult and will require a fair amount of force.
  • The plastic strip that guides the carriage is fragile and can be broken easily.
  • Pull carriage up from the bottom.
단계 4  ¶
Pull on the two white wire strips on the printer carriage to remove. Wire strips are fragile. Pull from connection to carriage and not the ribbon cable itself.
단계 4  ¶
  • Pull on the two white wire strips on the printer carriage to remove.
  • Wire strips are fragile. Pull from connection to carriage and not the ribbon cable itself.
단계 5  ¶
Place new printer carriage on the carriage rod one side at a time. For proper reassembly, place the printer carriage’s black lip beneath the overhanging metal flap at the back of the printer. For proper reassembly, place the printer carriage’s black lip beneath the overhanging metal flap at the back of the printer.
단계 5  ¶
  • Place new printer carriage on the carriage rod one side at a time.
  • For proper reassembly, place the printer carriage’s black lip beneath the overhanging metal flap at the back of the printer.
