도움말
Samsung Jack Keyboard Replacement
Installing the Samsung Jack's keyboard.
  • 작성자: Jaime Serrano
  • 예상 시간 15 분
  • 난이도: 어려움
Use this guide to remove the old keyboard and install a new one.
섹션
단계 1 Keyboard  ¶
The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool between the LCD frame and the front case of the phone. Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
단계 1 Keyboard  ¶
  • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
  • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
  • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
단계 2  ¶
Lift up the LCD frame. Lift up the LCD frame.
단계 2  ¶
  • Lift up the LCD frame.
단계 3  ¶
The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard. The keyboard and directional keys are glued separately to the LCD frame. Insert the spudger between the keyboard and the frame.
단계 3  ¶
  • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
  • The keyboard and directional keys are glued separately to the LCD frame.
  • Insert the spudger between the keyboard and the frame.
  • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
단계 4  ¶
Insert the spudger between the directional keys and the frame. Peel the directional keys off by sliding the spudger back and forth across the LCD frame. Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
단계 4  ¶
  • Insert the spudger between the directional keys and the frame.
  • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
