도움말
HTC Touch Pro CDMA USB Motherboard Replacement
How to replace the motherboard of the HTC Touch Pro.
Replacement of the HTC Touch Pro's motherboard.
단계 1 USB Logic Board  ¶
Remove the 4 screws using the T6 screw driver.
  • Remove the 4 screws using the T6 screw driver.
단계 2  ¶
Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
단계 2  ¶
  • Lift the plastic cover near the memory card slot.
단계 3  ¶
Remove the two Phillips #00 screws from the backside of the screen.
단계 3  ¶
  • Remove the two Phillips #00 screws from the backside of the screen.
단계 4  ¶
Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
단계 4  ¶
  • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
  • Gently pry apart the two halves of the phone.
단계 5  ¶
Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
단계 5  ¶
  • Gently unplug the connectors.
  • Remove the screws with a 00 Phillips-head screwdriver.
단계 6  ¶
Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
단계 6  ¶
  • Gently lift the motherboard up using a nylon spudger.
  • BE AWARE OF THE ANTENNA.
