메인 콘텐츠로 스킵하기
도움말
Motorola Slvr L7 Keypad Replacement
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
잘못된 도구
잘못된 도구
이미지 및/또는 텍스트의 올바른 도구를 사용하여 해당 안내서를 더 효과적으로 만들어 주십시오.
A Step-by-Step guide to complete disassembly of Motorola phone into it's main components.
Use this guide to replace the keypad.
단계 1 Keypad  ¶
Push down on the black tab located at the top center of the Motorola phone
단계 1 Keypad  ¶
  • Push down on the black tab located at the top center of the Motorola phone
단계 2  ¶
Remove the battery by pulling the battery from the top center
단계 2  ¶
  • Remove the battery by pulling the battery from the top center
단계 3  ¶
Remove the four (4) T6 Torx screws from the rear metal plate.
단계 3  ¶
  • Remove the four (4) T6 Torx screws from the rear metal plate.
단계 4  ¶
Insert the flat end of a spudger and pry the metal cover up off the phone Insert the flat end of a spudger and pry the metal cover up off the phone
단계 4  ¶
  • Insert the flat end of a spudger and pry the metal cover up off the phone
단계 5  ¶
Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
단계 5  ¶
  • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
단계 6  ¶
Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
단계 6  ¶
  • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
  • De-route the antenna cable by pulling it out.
단계 7  ¶
Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
단계 7  ¶
  • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
  • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
  • Be careful not to loose the round plastic piece that covers the microphone.
단계 8  ¶
Remove the 2 newly exposed T6 screws Remove the 2 newly exposed T6 screws
단계 8  ¶
  • Remove the 2 newly exposed T6 screws
단계 9  ¶
Starting at the top, insert the flat end of a spudger and pry the frame of the phone. The frame is attached by several clips, so some force may be required to dislodge the first clip.
단계 9  ¶
  • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
  • The frame is attached by several clips, so some force may be required to dislodge the first clip.
  • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
단계 10  ¶
Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
단계 10  ¶
  • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
