메인 콘텐츠로 스킵하기
도움말
MacBook Pro 15" Unibody Early 2011 Hard Drive Replacement
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
Hard Drive prereq.
This guide is a prereq only.
단계 1 Hard Drive  ¶
Remove two Phillips screws securing the hard drive bracket to the upper case.
단계 1 Hard Drive  ¶
  • Remove two Phillips screws securing the hard drive bracket to the upper case.
  • These screws are captive to the hard drive bracket.
단계 2  ¶
Lift the retaining bracket out of the upper case.
단계 2  ¶
  • Lift the retaining bracket out of the upper case.
단계 3  ¶
Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
단계 3  ¶
  • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
단계 4  ¶
Remove the hard drive cable by pulling its connector straight away from the hard drive. Remove the hard drive cable by pulling its connector straight away from the hard drive.
단계 4  ¶
  • Remove the hard drive cable by pulling its connector straight away from the hard drive.
