도움말
MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
AirPort/Bluetooth Board Assembly prereq.
This guide is prereq only.
단계 1 AirPort/Bluetooth Board Assembly  ¶
Pull the camera cable connector straight out of its socket on the logic board.
  • Pull the camera cable connector straight out of its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the optical drive opening.
단계 2  ¶
Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
단계 2  ¶
  • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
단계 3  ¶
Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board. Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
단계 3  ¶
  • Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
단계 4  ¶
De-route all four antenna cables from their channels in the AirPort/Bluetooth housing. De-route the camera cable from its channel in the AirPort/Bluetooth housing. De-route the camera cable from its channel in the AirPort/Bluetooth housing.
단계 4  ¶
  • De-route all four antenna cables from their channels in the AirPort/Bluetooth housing.
  • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
단계 5  ¶
Remove the following two screws securing the AirPort/Bluetooth assembly to the upper case:
단계 5  ¶
  • Remove the following two screws securing the AirPort/Bluetooth assembly to the upper case:
  • One 8.6 mm Phillips screw
  • One 3.9 mm Phillips screw
단계 6  ¶
Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
단계 6  ¶
  • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
