메인 콘텐츠로 스킵하기
도움말
iMac Intel 21.5" EMC 2428 IR Board Replacement
Replace the IR board in your iMac Intel 21.5" EMC 2428.
Use this guide to replace the sleep light/IR board.
단계 1 IR Board  ¶
If present, remove the piece of clear tape covering the IR board connector. Pull the IR board connector toward the top of the iMac to disconnect it from the logic board.
단계 1 IR Board  ¶
  • If present, remove the piece of clear tape covering the IR board connector.
  • Pull the IR board connector toward the top of the iMac to disconnect it from the logic board.
단계 2  ¶
Use your fingers to lift IR sensor assembly straight up and out of the outer case.
단계 2  ¶
  • Use your fingers to lift IR sensor assembly straight up and out of the outer case.
