도움말
iMac Intel 21.5" EMC 2428 CPU Fan Replacement
Replace the CPU fan in your iMac Intel 21.5" EMC 2428.
  • 작성자: Walter Galan
  • 예상 시간 2 - 3 시간
  • 난이도: 어려움
Replace a broken CPU fan to keep temperatures down.
섹션
단계 1 CPU Fan  ¶
Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
단계 1 CPU Fan  ¶
  • Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
단계 2  ¶
Pull the CPU fan straight up from its mounting pin near the bottom edge of the iMac.
단계 2  ¶
  • Pull the CPU fan straight up from its mounting pin near the bottom edge of the iMac.
단계 3  ¶
Being careful not to put too much strain on the left speaker cable, flip the CPU fan over to expose its bottom edge. Use the flat end of a spudger to press down one side of the speaker cable retainer as you use your other hands to slide the speaker cables out of the retainer.
단계 3  ¶
  • Being careful not to put too much strain on the left speaker cable, flip the CPU fan over to expose its bottom edge.
  • Use the flat end of a spudger to press down one side of the speaker cable retainer as you use your other hands to slide the speaker cables out of the retainer.
  • Remove the CPU fan from the iMac.
