도움말
MacBook Air 11" Mid 2011 AirPort/Bluetooth Card Replacement
Replace the AirPort/Bluetooth card on your Mid 2011 MacBook Air 11".
Use this guide to replace a failed AirPort/Bluetooth card. Note that the the airport antenna cables in the Macbook Air 11.6 inch 2011 model are longer than that of the 2010 model. If you're thinking of an easy swap of screen assembly between these two models, it will not work.
단계 1 AirPort/Bluetooth Card  ¶
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
단계 2  ¶
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
단계 2  ¶
  • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
단계 3  ¶
Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
단계 3  ¶
  • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
  • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  • Remove the AirPort/Bluetooth board from the Air.
