메인 콘텐츠로 스킵하기
도움말
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Replace the solid state hard drive on your Mid 2011 MacBook Air 11".
  • 작성자: Walter Galan
  • 예상 시간 6 - 10 분
  • 난이도: 쉬움
Use this guide to upgrade or replace the solid-state drive in a MacBook Air 11” Mid 2011. This MacBook Air uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Air. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
단계 1 Solid-State Drive  ¶
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
단계 2  ¶
Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand. Do not lift the end of the SSD excessively.
단계 2  ¶
  • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
  • Do not lift the end of the SSD excessively.
  • Pull the drive straight out of its socket and remove it from the logic board.
  • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
