도움말
Mac mini Mid 2011 I/O Bezel Replacement
Replacing the I/O bezel.
Use this guide to replace the I/O bezel and its integrated antennas. Replacing the I/O bezel will also give you a new power button.
단계 1 I/O Bezel  ¶
Carefully un-clip the antenna from the logic board near the heat sink.
단계 1 I/O Bezel  ¶
  • Carefully un-clip the antenna from the logic board near the heat sink.
단계 2  ¶
Carefully un-clip the antenna from the logic board near the PRAM battery. Gently de-route the antenna cable through the hole in the logic board.
단계 2  ¶
  • Carefully un-clip the antenna from the logic board near the PRAM battery.
  • Gently de-route the antenna cable through the hole in the logic board.
단계 3  ¶
Carefully un-clip the antenna from the logic board opposite the I/O bezel. De-route the antenna cable from the clips on the logic board near the I/O bezel.
단계 3  ¶
  • Carefully un-clip the antenna from the logic board opposite the I/O bezel.
  • De-route the antenna cable from the clips on the logic board near the I/O bezel.
단계 4  ¶
Lift the power button cables upward to gently pull the power button cable up and out of its connector on the logic board.
단계 4  ¶
  • Lift the power button cables upward to gently pull the power button cable up and out of its connector on the logic board.
단계 5  ¶
Remove the following screws securing the I/O bezel to the front side of the logic board:
단계 5  ¶
  • Remove the following screws securing the I/O bezel to the front side of the logic board:
  • Three 2.6 mm T6 Torx screws
  • One 2.9 mm T6 Torx screw
단계 6  ¶
Remove the single 2.6 mm T6 Torx screw securing the I/O bezel to the logic board near the RAM.
단계 6  ¶
  • Remove the single 2.6 mm T6 Torx screw securing the I/O bezel to the logic board near the RAM.
단계 7  ¶
Pull the I/O bezel away from the logic board, minding any cables that may get caught.
단계 7  ¶
  • Pull the I/O bezel away from the logic board, minding any cables that may get caught.
  • Try not to handle the small steel EMI fingers on the logic board and I/O bezel, as oils from your fingers may cause interference issues. Before installing the logic board assembly, clean the EMI fingers to remove any oils transferred during the removal process.
