메인 콘텐츠로 스킵하기
도움말
PS3 Wireless Controller Teardown
분해도
분해도
분해도는 device의 내부를 보여주는 정보일 뿐 분해 설명서로 사용하면 안됩니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
If you are reading this in order to learn how to repair your controller, don't this will only be a guide of how to TEAR IT DOWN not disassemble.
단계 1 Unscrewing it  ¶
Flip the controller upside down.
  • Flip the controller upside down.
  • Unscrew the 5 screws (marked out in orange in the picture).
단계 2 Unhooking the battery  ¶
Once the cover is off, the controller should look like this. Follow the red and black wire(s) from the battery to the connector. Take a pair of small pliers and unhook the battery (refer to picture 2 of this step to see it unhooked). The battery will simply lift out revealing the motherboard (refer to picture 3 ots).
  • Once the cover is off, the controller should look like this. Follow the red and black wire(s) from the battery to the connector.
  • Take a pair of small pliers and unhook the battery (refer to picture 2 of this step to see it unhooked).
  • The battery will simply lift out revealing the motherboard (refer to picture 3 ots).
  • From here, the plastic holding the battery will be able to lifted out.
단계 3 Removing the L1,L2 and R1,R2 buttons.  ¶
This will be the step where you teardown the controller not take it apart. To remove the 4 buttons (2 on each side), first lift out the R1 (or L1) button.  This may require you to wiggle the button.
  • This will be the step where you teardown the controller not take it apart.
  • To remove the 4 buttons (2 on each side), first lift out the R1 (or L1) button. This may require you to wiggle the button.
  • From here, you will have to apply force to tear out the R2 (or L2) button and the plastic it is connected to. In the 2 pictures (ots) you can see one side taken apart and the other as it normally is.
단계 4 Removing the vibration motors.  ¶
For this step, you will need to de-solder the wires that connect the motors to motherboard. Or, if you are like me and don't have a solder, you can attempt to rip the wires of. First of, lift the whole motor out of the plastic mount. This may take some force as it is glued in.
  • For this step, you will need to de-solder the wires that connect the motors to motherboard. Or, if you are like me and don't have a solder, you can attempt to rip the wires of.
  • First of, lift the whole motor out of the plastic mount. This may take some force as it is glued in.
  • After that, simply cut the cable off of the motherboard, or de-solder it. In the first picture you can see what your controller will look like with one motor missing.
  • Repeat the same on the other side.
단계 5 Removing the motherboard  ¶
First off, unscrwew the single screw that holds the motherboard onto the plastic (marked out in orange in the first and second picture ots). With that screw removed, the whole motherboard (along with the 2 joysticks) can be simply lifted right out. Pictures 2 and 3 show the case without the motherboard and joysticks.
  • First off, unscrwew the single screw that holds the motherboard onto the plastic (marked out in orange in the first and second picture ots).
  • With that screw removed, the whole motherboard (along with the 2 joysticks) can be simply lifted right out.
  • Pictures 2 and 3 show the case without the motherboard and joysticks.
단계 6 Removing the white plastic.  ¶
To remove the white plastic, simply lift it out of the controller. There are no screws,clips or glue holding it in. Pictures 2 and 3 show the plastic by itself. Pictures 2 and 3 show the plastic by itself.
  • To remove the white plastic, simply lift it out of the controller. There are no screws,clips or glue holding it in.
  • Pictures 2 and 3 show the plastic by itself.
단계 7 Removing the remaining buttons  ¶
First of, remove the 2 white pieces or rubber on the sides and the middle, grey piece too. The first picture shows you what this will look like. Then simply "pop" the buttons out (marked out in orange in picture 2) from the other side (the front). You can also remove the "Play Station" logo button. For the other side, remove the top plastic and then the 4 buttons (made of one piece of plastic).
  • First of, remove the 2 white pieces or rubber on the sides and the middle, grey piece too. The first picture shows you what this will look like.
  • Then simply "pop" the buttons out (marked out in orange in picture 2) from the other side (the front). You can also remove the "Play Station" logo button.
  • For the other side, remove the top plastic and then the 4 buttons (made of one piece of plastic).
단계 8 Remove the final plastic piece  ¶
The final piece to remove is the plastic battery level light cover. This is done by simply pressing in the 4 (slightly protruding) pieces of plastic. The 3 pictures show the the case completely stripped out.
  • The final piece to remove is the plastic battery level light cover.
  • This is done by simply pressing in the 4 (slightly protruding) pieces of plastic.
  • The 3 pictures show the the case completely stripped out.
단계 9  ¶
없는 이미지
단계 9  ¶
  • And thats that. If you have been following the guide, you now have a completely stripped down PS3 controller. If you have read this for entertainment, you now know what it takes to strip down a PS3 controller. Thank you for reading.
