도움말
Disassembling Kodak Advantix F350 Front Cover
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This guide demonstrates how to remove the front and back cover from the camera.
단계 1 Front Cover  ¶
Locate the 3 screws on the camera that hold the front cover of the camera to the camera body. The first 2 are located on the bottom of the camera.
단계 1 Front Cover  ¶
  • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
  • The first 2 are located on the bottom of the camera.
  • The last screw is located behind the flash module.
  • Turn the camera on, and raise the flash module to locate the flash module screw.
단계 2  ¶
Remove the 2 screws at the base of the camera housing. Use the Phillips #00 Precision Screwdriver and remove the screws.
단계 2  ¶
  • Remove the 2 screws at the base of the camera housing.
  • Use the Phillips #00 Precision Screwdriver and remove the screws.
  • Repeat this process for the screw behind the flash module.
단계 3  ¶
Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver. Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
단계 3  ¶
  • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
단계 4  ¶
Remove the flash cover. Remove the flash module by twisting it up and outward of the camera housing.
단계 4  ¶
  • Remove the flash cover.
  • Remove the flash module by twisting it up and outward of the camera housing.
  • The cover can now be be removed.
단계 5  ¶
Remove the film door lever. Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
단계 5  ¶
  • Remove the film door lever.
  • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
  • Using a plastic opening tool, gently pry the switch upwards to remove it.
단계 6  ¶
Open the battery door by pushing the lever towards the arrow indicated.
단계 6  ¶
  • Open the battery door by pushing the lever towards the arrow indicated.
단계 7  ¶
Remove the front cover. Insert your thumb in the film hole and gently pry the bottom loose. Once the front is loose, gently pull it out.
단계 7  ¶
  • Remove the front cover.
  • Insert your thumb in the film hole and gently pry the bottom loose.
  • Once the front is loose, gently pull it out.
