메인 콘텐츠로 스킵하기
도움말
Palm m105 Display Screen Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
This guide will help you to replace the screen display on your Palm m105.
단계 1 Display Screen  ¶
Remove protective flap by pulling directly out from the top.
  • Remove protective flap by pulling directly out from the top.
  • The two clips will pop out
단계 2  ¶
Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
단계 2  ¶
  • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
  • The Faceplate will then easily lift off.
단계 3  ¶
Using a a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise. The link to purchase this screwdriver is Located here.
단계 3  ¶
  • Using a a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
  • The link to purchase this screwdriver is Located here.
단계 4  ¶
This is what the device looks like once you have taken the screws out and opened the device.
단계 4  ¶
  • This is what the device looks like once you have taken the screws out and opened the device.
단계 5  ¶
The Motherboard and screen will pop out of the back case easily.
단계 5  ¶
  • The Motherboard and screen will pop out of the back case easily.
  • Be careful when doing this step, the components are fragile.
단계 6  ¶
To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
단계 6  ¶
  • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
  • ** This step needs to be done with special care because it is very fragile.**
  • Once they are all three popped up the motherboard and screen will separate easily.
단계 7  ¶
Click here for Palm m105 screen replacement
단계 7  ¶
  • Click here for Palm m105 screen replacement
  • Now that the screen and motherboard are separated you may discard the broken screen. The best way to dispose of the broken screen is to: Recycle it
