도움말
Nokia N70 Back Camera Replacement
  • 작성자: Justin
  • 예상 시간 25 - 30 분
  • 난이도: 보통
단계 1 Back Camera  ¶
Using T6 Torx screwdriver remove the six 15 mm torx screws. Using T6 Torx screwdriver remove the six 15 mm torx screws.
단계 1 Back Camera  ¶
  • Using T6 Torx screwdriver remove the six 15 mm torx screws.
단계 2  ¶
Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle. Remove the front panel by lifting the panel away from the phone at a 45 degree angle. Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
단계 2  ¶
  • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
  • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
단계 3  ¶
Locate the rear circuit board by flipping over the front panel. Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot. Caution: Be careful when prying camera out of the slot for the connections are fragile.
단계 3  ¶
  • Locate the rear circuit board by flipping over the front panel.
  • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
  • Caution: Be careful when prying camera out of the slot for the connections are fragile.
