도움말
iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
Removing or Replacing logic board on a 17 inch iMac G4.
  • 작성자: Justin
  • 난이도: 보통
Removing the logic board assembly to replace it with a new one.
단계 1 Logic Board Assembly  ¶
Gently remove the cables marked in red.
  • Gently remove the cables marked in red.
단계 2  ¶
Remove the three metal 10mm T-15 screws.
단계 2  ¶
  • Remove the three metal 10mm T-15 screws.
  • Remove the one nylon 10mm T-15 screw.
단계 3  ¶
Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
단계 3  ¶
  • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
