메인 콘텐츠로 스킵하기
도움말
Dell Inspiron 530 CD/DVD Drive Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
Removing the CD/DVD drive
  • 작성자: Doug Howe
  • 예상 시간 5 - 7 분
  • 난이도: 보통
This guide will demonstrate removing the computer's CD/DVD drive.
섹션
도구
단계 1 CD/DVD Drive  ¶
Locate the CD/DVD drive in the upper-front corner of the case.
단계 1 CD/DVD Drive  ¶
  • Locate the CD/DVD drive in the upper-front corner of the case.
단계 2  ¶
Locate and remove the two cables attached to the CD/DVD drive.
단계 2  ¶
  • Locate and remove the two cables attached to the CD/DVD drive.
단계 3  ¶
Locate and remove the two Phillips #0 7.8 mm screws.
단계 3  ¶
  • Locate and remove the two Phillips #0 7.8 mm screws.
단계 4  ¶
Locate the three plastic tabs connecting the computer's faceplate to the case.
단계 4  ¶
  • Locate the three plastic tabs connecting the computer's faceplate to the case.
  • Gently lift the three tabs to pull off the faceplate.
단계 5  ¶
Pull the faceplate forward and out.
단계 5  ¶
  • Pull the faceplate forward and out.
단계 6  ¶
Completely remove the faceplate.
단계 6  ¶
  • Completely remove the faceplate.
  • Remove the CD/DVD drive by pulling it forward towards the front.
