메인 콘텐츠로 스킵하기
도움말
iPhone 4S Rear Panel Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Replace a cracked rear panel on your iPhone 4S.
  • 작성자: Walter Galan
  • 예상 시간 10 분
  • 난이도: 쉬움
Remove the rear panel to access the internal components of your iPhone.
단계 1 Rear Panel  ¶
Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
단계 1 Rear Panel  ¶
  • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
  • Be sure the driver is well-seated when removing Pentalobe screws—they are easy to strip.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
단계 2  ¶
Push the rear panel toward the top edge of the iPhone. The panel will move about 2 mm.
단계 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
단계 3  ¶
Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
단계 3  ¶
  • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
  • Remove the rear panel from the iPhone.
