메인 콘텐츠로 스킵하기
도움말
iPhone 4S Rear Camera Replacement
Removing your iPhone 4S's 8 MP rear camera.
  • 작성자: Walter Galan
  • 예상 시간 30 분 - 2 시간
  • 난이도: 보통
Use this guide to remove the iPhone's primary rear camera.
단계 1 Rear Camera  ¶
Be wary of the outer plastic ring located on top of the rear camera's flash assembly. It can be easily displaced if not removed during disassembly.
단계 1 Rear Camera  ¶
  • Be wary of the outer plastic ring located on top of the rear camera's flash assembly. It can be easily displaced if not removed during disassembly.
  • You can use tweezers, a plastic opening tool, or a spudger to remove the outer plastic ring.
단계 2  ¶
Remove the following four screws securing the cable cover to the logic board:
단계 2  ¶
  • Remove the following four screws securing the cable cover to the logic board:
  • One 2.7 mm Phillips screw
  • One 2.6 mm Phillips screw
  • One 1.3 mm Phillips screw
  • One 1.2 mm Phillips screw
단계 3  ¶
Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board. Lift the cable cover from its edge nearest the top and remove it from the iPhone.
단계 3  ¶
  • Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
  • Lift the cable cover from its edge nearest the top and remove it from the iPhone.
단계 4  ¶
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board. Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
단계 4  ¶
  • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
  • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
  • Remove the rear camera from the iPhone.
  • There is a small rubber gasket that sits underneath the rear-facing camera. Make sure that it is properly seated before reassembly.
