도움말
기술: How to load HP Deskjet 6122 paper
보관된 가이드
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Many problems are associated with a paper tray being low. This is a common problem and is quite easy to fix.
  • 작성자: Joe
  • 난이도: 보통
This guide will walk you through how to change the paper and common problems and solutions associated with being low on paper.
단계 1 How to load HP Deskjet 6122 paper  ¶
Open the paper tray to see if it is empty.
  • Open the paper tray to see if it is empty.
단계 2  ¶
If the paper tray is empty, add paper to the tray.
단계 2  ¶
  • If the paper tray is empty, add paper to the tray.
  • If there is already paper in the tray, realign the paper so that it fits in the gears, and can feed through properly.
단계 3  ¶
Ensure that all paper is in the correct tray.
단계 3  ¶
  • Ensure that all paper is in the correct tray.
  • The correct tray is on the upper deck of the printer.
단계 4  ¶
Run the printer to verify it now prints.
단계 4  ¶
  • Run the printer to verify it now prints.
  • If the paper still does not run through the printer, inspect the paper tray again.
단계 5  ¶
Remove any paper that looks to be overloading the tray feeder.
단계 5  ¶
  • Remove any paper that looks to be overloading the tray feeder.
  • Sometimes there can be too much paper in the tray, preventing it from working properly.
단계 6  ¶
Try to print one last time. If it still fails, consider consulting a page to update drivers.
단계 6  ¶
  • Try to print one last time. If it still fails, consider consulting a page to update drivers.
