메인 콘텐츠로 스킵하기
도움말
LG CU400 Motherboard Replacement
Following this guide will allow you to replace the motherboard in the LG CU400.
  • 작성자: Ross Brown
  • 예상 시간 25 분
  • 난이도: 보통
This guide will walk you through the steps to remove the motherboard from your LG CU400. It will help remove the battery, the lower half casing, and the actual removal of the motherboard from the phone casing. Before doing this, be aware that you will be unable to use your phone until the replacement is complete. You should also be careful when handling the motherboard because it has delicate wires extending from it.
단계 1 Motherboard  ¶
You should notice that the number pad is loose and can simply be taken out of the open phone casing. You should notice that the number pad is loose and can simply be taken out of the open phone casing. You should notice that the number pad is loose and can simply be taken out of the open phone casing.
단계 1 Motherboard  ¶
  • You should notice that the number pad is loose and can simply be taken out of the open phone casing.
단계 2  ¶
Using the spudger, start to gently pry the motherboard from the back of the phone and work your way around the perimeter of the motherboard. There are copper ribbon cables connected to each side of the motherboard leading to the buttons for volume control and the camera that need slid out of the phone casing as the motherboard is being removed.
단계 2  ¶
  • Using the spudger, start to gently pry the motherboard from the back of the phone and work your way around the perimeter of the motherboard.
  • There are copper ribbon cables connected to each side of the motherboard leading to the buttons for volume control and the camera that need slid out of the phone casing as the motherboard is being removed.
  • There are three in total, but do not remove the top one from the phone casing yet.
단계 3  ¶
Once the motherboard is not locked in place it will still be attached to the back phone casing by two wires, red and black, twisted together.
단계 3  ¶
  • Once the motherboard is not locked in place it will still be attached to the back phone casing by two wires, red and black, twisted together.
  • Use tweezers to grab the black piece that these wires are attached to and simply pull it off the motherboard.
  • You may need to flip the phone over so that the screen is facing down. Feel free to move the keypad assembly to the closed position for this step.
단계 4  ¶
Remove the display ribbon cable from the back of the motherboard using tweezers.
단계 4  ¶
  • Remove the display ribbon cable from the back of the motherboard using tweezers.
  • Make sure to lift it so that you are pulling the entire thing off at once and not pulling off the flat piece at an angle.
단계 5  ¶
Use tweezers to remove the top ribbon cable, mentioned in step 11, from the hinge area.
단계 5  ¶
  • Use tweezers to remove the top ribbon cable, mentioned in step 11, from the hinge area.
단계 6  ¶
Grasp either side of the motherboard and gently lift it away from the phone casing. The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures. The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures.
단계 6  ¶
  • Grasp either side of the motherboard and gently lift it away from the phone casing.
  • The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures.
