도움말
Palm m 100 Cover Replacement
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
전제 조건 누락
전제 조건 누락
해당 안내서는 작업 시작 방법에 대한 정보가 없습니다. 전제 조건 안내서를 만들어 주십시오!
단계 다듬기
단계 다듬기
해당 안내서에는 불필요한 단계들이 있습니다. 단계들을 다듬어 더욱 간결하게 만들어 주십시오!
This guide will enable the user to remove and replace the cover.
If the front and/or rear cover is cracked, this guide will teach the user to remove the damaged cover and replace with a new one.
단계 1 Cover  ¶
Remove the batteries.
단계 1 Cover  ¶
  • Remove the batteries.
단계 2  ¶
Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
단계 2  ¶
  • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
단계 3  ¶
Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
단계 3  ¶
  • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
단계 4  ¶
Set aside broken cover, and replace with a new cover.
단계 4  ¶
  • Set aside broken cover, and replace with a new cover.
단계 5  ¶
Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
단계 5  ¶
  • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
단계 6  ¶
Put the back cover on the device and screw the four screws, screwing in a clockwise direction.  Take caution not to over-tighten the screws.
단계 6  ¶
  • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
