도움말
Olympus Camedia D560 Battery Compartment Cover Replacement
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
Removal of the back cover, front cover, and battery compartment cover.
단계 1 Battery Compartment Cover  ¶
Remove all five screws found on the outer shell of the camera. You will find three along the bottom (see picture #1) and two more up one side (the side closest to the LCD screen). You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well. Once all screws are removed, use a blue iPod opening tool (seen in picture #3) to carefully pry the back outer shell away from the rest of the camera.
  • Remove all five screws found on the outer shell of the camera. You will find three along the bottom (see picture #1) and two more up one side (the side closest to the LCD screen).
  • You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well.
  • Once all screws are removed, use a blue iPod opening tool (seen in picture #3) to carefully pry the back outer shell away from the rest of the camera.
단계 2  ¶
Completely separate the back cover from the rest of the camera. Set the back cover aside. Remove 4 screws from the front outer cover to the camera (see image #2 for screw locations). Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
단계 2  ¶
  • Completely separate the back cover from the rest of the camera. Set the back cover aside.
  • Remove 4 screws from the front outer cover to the camera (see image #2 for screw locations).
  • Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
단계 3  ¶
Unplug the yellow and black wires connecting the front outer cover of the camera to the rest of the camera, as shown in image #2. This can be done by gently unplugging the end of the wire connected to the inner casing of the camera. The front outer cover should now be completely separated from the rest of the camera. The front outer cover should now be completely separated from the rest of the camera.
단계 3  ¶
  • Unplug the yellow and black wires connecting the front outer cover of the camera to the rest of the camera, as shown in image #2. This can be done by gently unplugging the end of the wire connected to the inner casing of the camera.
  • The front outer cover should now be completely separated from the rest of the camera.
단계 4  ¶
Carefully set aside the front outer cover of the camera. Then, locate the two screws attaching the battery compartment cover to the rest of the camera (see picture #2). Remove the 2 screws attaching the battery compartment cover to the rest of the camera. Once both screws are removed, the back hinge of the battery compartment cover will flip up (see picture #3).
단계 4  ¶
  • Carefully set aside the front outer cover of the camera. Then, locate the two screws attaching the battery compartment cover to the rest of the camera (see picture #2).
  • Remove the 2 screws attaching the battery compartment cover to the rest of the camera.
  • Once both screws are removed, the back hinge of the battery compartment cover will flip up (see picture #3).
단계 5  ¶
Your battery compartment cover should now be completely removed and ready for repair or replacement.
단계 5  ¶
  • Your battery compartment cover should now be completely removed and ready for repair or replacement.
