메인 콘텐츠로 스킵하기
도움말
Dell Inspiron 1525 Bottom Cover Replacement
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
단계 1 Bottom Cover  ¶
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel. The screws may only need to be loosened, as they are generally retained by plastic washers.
단계 1 Bottom Cover  ¶
  • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
  • The screws may only need to be loosened, as they are generally retained by plastic washers.
  • Remove the bottom panel.
