도움말
iPod Nano 3rd Generation Logic Board Replacement
  • 작성자: Walter Galan
  • 예상 시간 40 분 - 1 시간
  • 난이도: 어려움
The motherboard/battery assembly is sold together.
단계 1 Logic Board  ¶
With the rear case removed, the back side of your Nano should now look like this.
단계 1 Logic Board  ¶
  • With the rear case removed, the back side of your Nano should now look like this.
단계 2  ¶
Remove the following six screws:
단계 2  ¶
  • Remove the following six screws:
  • One 1.8 mm Phillips.
  • Three 1.9 mm Phillips.
  • One 2.4 mm Phillips.
  • One 2.6 mm Phillips.
단계 3  ¶
Using a spudger, flip up the brown click wheel ribbon cable retaining clip. The clip is hinged at the end nearest the edge of the case.
단계 3  ¶
  • Using a spudger, flip up the brown click wheel ribbon cable retaining clip.
  • The clip is hinged at the end nearest the edge of the case.
단계 4  ¶
Use the tip of a spudger to slide the click wheel ribbon cable out of its socket.
단계 4  ¶
  • Use the tip of a spudger to slide the click wheel ribbon cable out of its socket.
  • The logic board is still connected to the iPod by the display ribbon cable.
단계 5  ¶
The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board. Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected).  Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
단계 5  ¶
  • The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board.
  • Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected). Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
단계 6  ¶
Use a spudger to flip up the display ribbon cable retaining clip.
단계 6  ¶
  • Use a spudger to flip up the display ribbon cable retaining clip.
  • The retaining clip is hinged about the end nearest the battery.
단계 7  ¶
Slide the display ribbon cable out of its socket.
단계 7  ¶
  • Slide the display ribbon cable out of its socket.
  • The logic board is now completely disconnected from the front case.
