메인 콘텐츠로 스킵하기
도움말
Dell Inspiron 1525 Display Assembly Replacement
Replace the display assembly on a Dell Inspiron 1525.
Use this guide to help you replace the display assembly on a Dell Inspiron 1525.
단계 1 Display Assembly  ¶
Disconnect the five antennas from their respective cards. De-route the antennas from their routing retainers. De-route the antennas from their routing retainers.
  • Disconnect the five antennas from their respective cards.
  • De-route the antennas from their routing retainers.
단계 2  ¶
Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
단계 2  ¶
  • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
  • The screw holes will be denoted by an embossed "D" by the hole.
단계 3  ¶
Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector. Carefully release the connector from its retaining tabs. Carefully release the connector from its retaining tabs.
단계 3  ¶
  • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
  • Carefully release the connector from its retaining tabs.
단계 4  ¶
Push the antenna wires up through their hole in the bottom case half. Release the antennas from their retaining tabs on the upper case.
단계 4  ¶
  • Push the antenna wires up through their hole in the bottom case half.
  • Release the antennas from their retaining tabs on the upper case.
단계 5  ¶
Disconnect the flat LCD ribbon cable by pulling it up by the tab. Free the ribbon cable from its retaining clips.
단계 5  ¶
  • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
  • Free the ribbon cable from its retaining clips.
단계 6  ¶
Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
단계 6  ¶
  • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
  • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
  • Remove the display assembly from the laptop.
