메인 콘텐츠로 스킵하기
도움말
Dell Inspiron 1525 Motherboard Replacement
Replace the motherboard in a Dell Inspiron 1525.
  • 작성자: Miroslav Djuric
  • 예상 시간 45 분 - 1 시간
  • 난이도: 어려움
Use this guide to help you replace the motherboard in a Dell Inspiron 1525.
단계 1 Motherboard  ¶
Use a spudger to push the retaining latch of the central control button connector towards its cable. Pull the cable out of the connector.
단계 1 Motherboard  ¶
  • Use a spudger to push the retaining latch of the central control button connector towards its cable.
  • Pull the cable out of the connector.
단계 2  ¶
Pull the retaining latch for the wireless sniffer cable out. Remove the cable from the connector.
단계 2  ¶
  • Pull the retaining latch for the wireless sniffer cable out.
  • Remove the cable from the connector.
단계 3  ¶
Disconnect the fan cable connector by pulling it towards the fan with a spudger. Disconnect the fan cable connector by pulling it towards the fan with a spudger.
단계 3  ¶
  • Disconnect the fan cable connector by pulling it towards the fan with a spudger.
단계 4  ¶
Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case. Gently peel the front bezel off. Lift the motherboard out of the lower case.
단계 4  ¶
  • Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case.
  • Gently peel the front bezel off.
  • Lift the motherboard out of the lower case.
  • If you are installing a new motherboard, make sure to transfer any remaining cables onto the new motherboard, as well as the CPU, RAM, modem, and Wi-Fi card.
