메인 콘텐츠로 스킵하기
도움말
iPod 5th Generation (Video) Hard Drive Replacement with a CF or SDHC/SDXC Memory Card
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
How to install a CF or SDHC/SDXC memory solution for iPod 5G (Video).
  • 작성자: Tsutomu Niimi
  • 예상 시간 15 - 30 분
  • 난이도: 보통
This Guide will show you how to replace the 1.8 HDD with a CF or SDHC/SDXC memory card. This might be useful to many people because a 1.8 HDD is hard to find and expensive. However, a decent CF card is almost as expensive and hard to find as a 1.8 HDD. The cheapest way to replace an iPod HDD is probably to use a SDHC/SDXC card.
단계 1 CF or SDHC/SDXC Memory instead of HDD  ¶
Now connect the ZIF to CF converter to the iPod's ZIF ribbon cable. You can also use a SD - CF adapter but not all will work. After reassembly you have to restore the iPod with iTunes. After reassembly you have to restore the iPod with iTunes.
  • Now connect the ZIF to CF converter to the iPod's ZIF ribbon cable. You can also use a SD - CF adapter but not all will work.
  • After reassembly you have to restore the iPod with iTunes.
