메인 콘텐츠로 스킵하기
도움말
1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Installing the MP3 changer in the BMW E39 requires simply disconnecting the CD changer and plugging in the replacement MP3 Player
A video about installing MP3 Player in BMW E39 http://www.youtube.com/watch?v=_6wg3qTvU....
단계 1 BMW E38 E39 X5 X3 Z4 E46 MP3 Player  ¶
Remove screws holding the CD changer in place (if equipped)
  • Remove screws holding the CD changer in place (if equipped)
  • Disconnect BMW CD changer 3 pin power plug and 6 pin audio plug from CD changer.
  • Connect MP3 Player to original CD changer connectors
단계 2  ¶
If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function. A good connection for BMWs built after Jan, 2000 production is the SES wiring plug, which is no longer used in cars that are equipped with the BMW Bluetooth system Switched power is located on pin 24 Violet/White (or Violet/Red  see image.
단계 2  ¶
  • If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function.
  • A good connection for BMWs built after Jan, 2000 production is the SES wiring plug, which is no longer used in cars that are equipped with the BMW Bluetooth system
  • Switched power is located on pin 24 Violet/White (or Violet/Red see image.
  • If you are also installing the DSP adapter module with your MP3 player you can connect the DSP module adapter to this pin in addition to using pin 14 brown/black for ground.
