도움말
PowerBook G4 Titanium Onyx DVD Drive Replacement
  • 작성자: iRobot
  • 난이도: 보통
Your machine may have come stock with a CD-RW or Combo drive instead of the DVD drive.
단계 1 DVD Drive  ¶
If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
단계 1 DVD Drive  ¶
  • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
  • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
단계 2  ¶
Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
단계 2  ¶
  • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
  • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
단계 3  ¶
Turn the G4 over.
단계 3  ¶
  • Turn the G4 over.
  • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
단계 4  ¶
Remove the DVD drive by lifting the right edge up and out of the computer.
단계 4  ¶
  • Remove the DVD drive by lifting the right edge up and out of the computer.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
