도움말
Asus Eee PC 1005HA Hard Drive Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
Replace the hard drive in your Asus Eee PC 1005HA.
Use this guide to replace or upgrade the hard drive in the Asus Eee PC 1005HA.
단계 1 Hard Drive  ¶
Flip the laptop over. Remove the four  5.65 mm screws from the bottom of the case.
단계 1 Hard Drive  ¶
  • Flip the laptop over.
  • Remove the four 5.65 mm screws from the bottom of the case.
  • Loosen the captive screw in the RAM compartment cover.
단계 2  ¶
Remove the panel covering the RAM. Pull the two RAM retaining arms away from the center of the RAM chip. Gently pull the RAM chip out of its socket.
단계 2  ¶
  • Remove the panel covering the RAM.
  • Pull the two RAM retaining arms away from the center of the RAM chip.
  • Gently pull the RAM chip out of its socket.
  • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
단계 3  ¶
Remove the single 6.65 mm screw next to the RAM socket.
단계 3  ¶
  • Remove the single 6.65 mm screw next to the RAM socket.
단계 4  ¶
Flip the laptop back over and open the display. Remove the six 5.5 mm screws from the metal plate beneath the keyboard.
단계 4  ¶
  • Flip the laptop back over and open the display.
  • Remove the six 5.5 mm screws from the metal plate beneath the keyboard.
단계 5  ¶
Using a plastic opening tool, carefully detach the five plastic clips securing the upper case. There are two small LEDs in the top edge of the lower casing, near the bottom right of the laptop. Be careful not to damage them as you pry open the plastic clips.
단계 5  ¶
  • Using a plastic opening tool, carefully detach the five plastic clips securing the upper case.
  • There are two small LEDs in the top edge of the lower casing, near the bottom right of the laptop. Be careful not to damage them as you pry open the plastic clips.
  • Carefully lift the upper case and flip it towards the front of the laptop.
단계 6  ¶
Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
단계 6  ¶
  • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
  • Slide the trackpad ribbon cable from its socket.
단계 7  ¶
Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector. Carefully pull the the I/O board ribbon cable from its sockets. Remove the two 4.6 mm screws holding the hard drive in place.
단계 7  ¶
  • Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector.
  • Carefully pull the the I/O board ribbon cable from its sockets.
  • Remove the two 4.6 mm screws holding the hard drive in place.
단계 8  ¶
Carefully slide the hard drive away from its socket. Use the attached pull tab to lift the hard drive up and out of the case.
단계 8  ¶
  • Carefully slide the hard drive away from its socket.
  • Use the attached pull tab to lift the hard drive up and out of the case.
  • When reinstalling the hard drive, be sure that the WiFi antenna cable (visible as a black loop below the disk in the 2nd photo) is not trapped or pinched beneath the drive.
단계 9  ¶
Remove the four 3.6 mm screws from the hard drive tray. Remove the hard drive from the tray.
단계 9  ¶
  • Remove the four 3.6 mm screws from the hard drive tray.
  • Remove the hard drive from the tray.
